Date/Time: Mon, 06 May 2024 01:13:08 +0000
Difference in Opening Price of a candlestick when compare to other platforms.
View Count: 686
[2018-04-08 10:01:31] |
User367844 - Posts: 3 |
Hi Support, I am doing a comparison between historical charts of different platforms to make sure the candlesticks HLOC are the same as I intend to switch from other platforms to Sierra platform. However, I happen to find out that there is 1 or 2 candlesticks "OPENING PRICE" difference for Sierra Chart when compare to other platforms' chart (I have done the comparison with 2 other different platforms) within 1-2 hours span. Any setting which I may have missed to have caused this? I'm running on a volume based historical chart. Please advice. Thanks. |
[2018-04-08 13:13:41] |
What is a volume-based historical chart? Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Also refer to help topic 43: Http://www.sierrachart.com/index.php?page=doc/helpdetails43.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-09 00:54:10] |
Hi, What I mean is I'm using volume chart. I have attached 2 pics for your reference. I have compare Sierra chart with 2 other platforms. Pic3 is comparison of Nin... with Sierra chart. Pic4 is from Multi.. If you see the highlighted candlestick, Nin.. and Multi.. have the same candlestick HLOC while Sierra's candlestick got different "Opening Price" for that particular candlestick. Is there any setting which could have caused this? Date Time Of Last Edit: 2018-04-09 02:23:43
Attachment Deleted. |
[2018-04-09 01:37:50] |
Those chart images are not acceptable. We need an image of the chart from Sierra Chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-09 06:57:39
