Date/Time: Thu, 02 May 2024 23:39:14 +0000
F-Secure reports trojan
View Count: 712
[2018-04-07 09:42:23] |
BrMa - Posts: 77 |
Dear ladies & gentlemen, F-Secure reports an trojan in the file SierraChart\Data\UserContributedStudies.dll Please check if there is anything suspicious. Thank you! Regards, Markus |
[2018-04-07 17:24:29] |
Refer to: Software Download: Antivirus/Anti-malware Software Flagging Sierra Chart Installer or other Files as Unsafe/Infected Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
