Date/Time: Tue, 10 Nov 2026 17:18:56 +0000
hi low for time period
View Count: 1073
| [2018-04-06 19:19:59] |
| User875891 - Posts: 63 |
Is it possible to add this study on another study independent of price? specifically a high low for an individual study not related to price Date Time Of Last Edit: 2018-04-06 19:55:44
| [2018-04-06 23:16:44] |
Yes, this is possible. Just change the Based On setting to the study you want to reference and set the Input Data High and the Input Data Low to the appropriate values. For more information, refer to: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study This is also explained more with the Inputs description here with the study: High/Low for Time Period: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
