Date/Time: Sat, 04 May 2024 06:55:14 +0000
Data Pricing
View Count: 955
[2018-04-05 19:32:24] |
User749205 - Posts: 38 |
Is it correct to say that if I want indices data on the Dax and Eurostoxx50, I pay $15, plus $21 Eurex exchange fee. But if I want also to see Bunds on the Eurex exchange, I pay $25, plus $21 exchange fee? How deep is the order book on each? Thanks. |
[2018-04-05 19:39:57] |
So did you want futures data for the EUREX? If so, the cost is 25 USD per month for 10 real-time 10 symbols, plus 21 USD per month for the EUREX exchange fee. Order book is 20 levels. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-05 20:10:06
[2018-04-05 19:48:18] |
Ok, great, that's good to know. I'm also curious about what's described as 'cash' indices data for $15. How is this different from the data provided freely (Sierra Chart Real Time and Historical Forex and CFD Data Service)? |
[2018-04-05 19:49:19] |
BTW, yes I'm after futures data for the Eurex.
[2018-04-05 22:10:40] |
Cash Indices are documented here: Sierra Chart Exchange Data Feed: Cash Indexes Cash Indices are the actual true cash index data and not CFDs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-09 19:48:59] |
That page states only US exchanges are covered by the cash indices data, is that so, and is there volume in that data? Do you offer the $5 trial on Eurex exchange data? Is it possible to have the SC exchange data and LMAX data at the same time, so that the exchange data can be monitored while, for example, using the LMAX DOM for order entry? Or is there another way to do this, SC exchange data DOM somehow translated into LMAX orders...? Thanks. |
[2018-04-09 20:22:43] |
That page states only US exchanges are covered by the cash indices data, is that so, and is there volume in that data? Yes that is the case. In regards to volume, for what particular symbol and we will check?Do you offer the $5 trial on Eurex exchange data? Is it possible to have the SC exchange data and LMAX data at the same time, so that the exchange data can be monitored while, for example, using the LMAX DOM for order entry? Yes. But just let us know for what particular symbols so we can make sure they are all set up for you when using LMAX.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-09 20:23:39
[2018-04-09 20:39:50] |
No problem, I don't need US indices, just making sure that was the case. Great! Sounds good, thanks. Although I'm not sure I understand, what is it you would set up? Can the LMAX data be better aligned to the exchange data? Is it possible to execute lmax orders from the ex data DOM? |
[2018-04-09 21:37:45] |
We just need to list the particular symbols either from the EUREX or CME in File >> Find Symbol that you want to use when using LMAX. There are just a handful of them currently requested by another user. We just add these on request. Can the LMAX data be better aligned to the exchange data? Is it possible to execute lmax orders from the ex data DOM? This is a whole other subject. Would be best that you analyze this from your perspective and then come back to us with some ideas that you have and we will see how we can help. The main problem is the pricing is going to be different.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-09 21:38:31
[2018-05-02 17:30:02] |
Could I get these Eurex symbols added to my LMAX trading feed please: FGBL FGBS FGBM FMWN FMWO Cheers |
[2018-05-02 17:41:51] |
Yes, we will add those.
[2018-05-04 05:10:28] |
Could I get these Eurex symbols added to my LMAX trading feed please: This is now done.
FGBL FGBS FGBM FMWN FMWO Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-04 05:23:22] |
Although FMWN is not available on the data feed we have.
