Date/Time: Sun, 28 Apr 2024 22:54:40 +0000
EA
View Count: 1380
[2018-04-05 13:01:22] |
User538995 - Posts: 11 |
Hello, I would like a very simple EA to put a sell stop or a buy stop according to my choice when I activate the EA; 1 tick below (in the case of the sell stop) or a tick at the top (buy stop) of the renko bar preditor, if the candle continues to lower or raise the buy stop or sell stop readjusts to the new candle. Is it possible to do this with sierra chart? |
[2018-04-05 19:18:14] |
Yes. You can do this using this particular study here: Attached Orders: Study Controlled Targets and Stops Also we do not know what is meant by the term EA. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
