Date/Time: Tue, 07 May 2024 00:50:40 +0000
error 'There are no fonts installed' under Graphics Settings
View Count: 583
[2018-04-04 22:04:19] |
User501309 - Posts: 6 |
I'm a demo user at this time, After only a few days I am hooked, SierraCharts blows anything else away. My problem is I get an error when under "Graphics Settings" in the Fonts tab, trying to choose any item and clicking 'select' I get an error "There are no fonts installed, Open the Fonts folder from the control Panel to install fonts." Obviously I have many fonts installed as is normal in any system these days. Is there a fix for this issue? Thanks, (using ver. 1727) and all else seems to be working very well without issues. |
[2018-04-05 01:28:01] |
That message you see is from the Windows operating system. It is *not* from Sierra Chart. We do not know what you need to do to solve it. Try running an Internet search for it and see what you can determine. It is also extremely rare, if ever, that we hear about someone encountering that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-05 01:28:27
