Date/Time: Sat, 04 May 2024 14:34:44 +0000
Color Background Based on Value Percentage, no option
View Count: 800
[2018-04-03 00:48:08] |
User926111 - Posts: 2 |
Hi, My study settings window doesnt appear to have this option to colour the background of the Number Bar Calculated Values study. I want it to behave the same as numbers bar background. I can colour the text but not the background. Hope it's nothing too obvious, Cheers |
[2018-04-05 15:08:58] |
John - SC Support - Posts: 31362 |
This option was introduced in version 1725. You need to be on that version or higher to be able to use this feature.
[2018-04-05 19:31:29] |
To update follow the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
