Date/Time: Tue, 07 May 2024 01:28:49 +0000
[Programming Help] - ZigZag Study
View Count: 577
[2018-04-01 07:01:50] |
nicktrader - Posts: 665 |
I'd like to display the Labels "HH" and "LL" only. Is there a way to filter it?
[2018-04-01 22:09:54] |
You really have to directly modify the study to meet your requirements. Here are the instructions: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-02 04:52:13] |
I see - April Fools' joke :-) :-)
[2018-04-02 07:02:22] |
April fools joke? Are you saying that this was not a real question or are you not satisfied with our answer? This is the first request for this, and while we can implement it, we think it is best that you take the source code and make the changes on your side to customize it as you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-02 07:32:02] |
It was your answer :-) :-) I would have to learn programming from scratch. Would it not be possible for you without much effort to split the display options for HL/ LL etc? |
