Date/Time: Mon, 29 Apr 2024 00:08:37 +0000
TPO value area lines
View Count: 706
[2018-03-31 13:49:28] |
bala - Posts: 74 |
Do you have any ASCIL function to access the TPO value area lines?
[2018-03-31 13:53:03] |
bala - Posts: 74 |
I just saw the documentation that you do not provide function. Please discard request
[2018-03-31 17:41:37] |
You need to use the method described here to access the data from that study. ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-01 19:20:11] |
bala - Posts: 74 |
THANKS VERY MUCH for pointing the documentation. I tried a small program (cut and paste from studies8.cpp) but it's not producing any result. I have made sure the study and subgraph exist ( I tried two different studies) The message log shows the returned value as 0.0000 |
[2018-04-01 19:54:24] |
bala - Posts: 74 |
Please ignore previous message, I was able to fix the problem ( I removed the %s from message and the values were printed). THANKS VERY MUCH for pointing to the documentation! |
