Date/Time: Sat, 04 May 2024 10:26:16 +0000
[Programming Help] - Source code
View Count: 1079
[2018-03-30 20:11:54] |
User39772 - Posts: 311 |
Hello Suppport, is it possible to get the source code of the study "write bar data to file" ? Regards |
[2018-03-30 21:32:15] |
This is available. Refer to: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-31 00:34:28] |
JoseyWales - Posts: 67 |
Around line 3107 in file "Studies6.cpp" SCSFExport scsf_WriteBarDataToFile(SCStudyInterfaceRef sc) { SCInputRef Separator = sc.Input[0]; SCInputRef UseGMTTime = sc.Input[1]; SCInputRef DateFormat = sc.Input[2]; SCInputRef OutputMilliseconds = sc.Input[3]; if (sc.SetDefaults) { sc.GraphName = "Write Bar Data To File"; sc.StudyDescription = "Write Bar Data To File"; sc.GraphRegion = 0; Separator.Name = "Separator"; Separator.SetCustomInputStrings("Space;Comma;Tab"); Separator.SetCustomInputIndex(1); UseGMTTime.Name = "Use GMT Time"; UseGMTTime.SetYesNo(0); DateFormat.Name = "Date Format"; DateFormat.SetCustomInputStrings("MM/DD/YYYY;YYYY/MM/DD;DD/MM/YYYY"); DateFormat.SetCustomInputIndex(1); OutputMilliseconds.Name = "Output Milliseconds"; OutputMilliseconds.SetYesNo(false); sc.TextInputName = "File Path"; sc.AutoLoop = 0;//manual looping for efficiency return; } SCString OutputPathAndFileName; if (sc.TextInput.GetLength() > 0) { OutputPathAndFileName = sc.TextInput; } else { OutputPathAndFileName.Format("%s-BarData.txt", sc.Symbol.GetChars()); } HANDLE FileHandle = INVALID_HANDLE_VALUE; DWORD BytesWritten; if (sc.UpdateStartIndex == 0) { // create new file FileHandle = CreateFile(OutputPathAndFileName.GetChars(), GENERIC_WRITE, 0, NULL, CREATE_ALWAYS, FILE_ATTRIBUTE_NORMAL, NULL); // creating/opening fail if (FileHandle == INVALID_HANDLE_VALUE) { SCString LogMessage; LogMessage.Format("Write Bar Data To File study: Error creating output data file: %s. Make sure the path is valid and there are no invalid characters.", OutputPathAndFileName.GetChars()); sc.AddMessageToLog(LogMessage.GetChars(), 1); return; } // write file header SCString FileHeader; switch (Separator.GetInt()) { case 0: FileHeader = "Date Time Open High Low Close Volume NumberOfTrades BidVolume AskVolume\r\n"; break; case 1: FileHeader = "Date, Time, Open, High, Low, Close, Volume, NumberOfTrades, BidVolume, AskVolume\r\n"; break; case 2: FileHeader = "Date\tTime\tOpen\tHigh\tLow\tClose\tVolume\tNumberOfTrades\tBidVolume\tAskVolume\r\n"; break; } WriteFile(FileHandle, FileHeader.GetChars(), (DWORD)FileHeader.GetLength(), &BytesWritten, NULL); } else { // open existing file FileHandle = CreateFile(OutputPathAndFileName.GetChars(), GENERIC_WRITE, 0, NULL, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL); // creating/opening fail if (FileHandle == INVALID_HANDLE_VALUE) { SCString LogMessage; LogMessage.Format("Write Bar Data To File study: Error creating output data file: %s", OutputPathAndFileName.GetChars()); sc.AddMessageToLog(LogMessage.GetChars(), 1); return; } SetFilePointer(FileHandle, 0, NULL, FILE_END); } bool IsRenko = sc.AreRenkoBars() != 0; for (int Index = sc.UpdateStartIndex; Index < (sc.ArraySize - 1); Index++) { if (sc.GetBarHasClosedStatus(Index) != BHCS_BAR_HAS_CLOSED) continue; // write on close int Year, Month, Day; int hour, minute, second, millisecond; SCDateTimeMS BaseDateTimeIn = sc.BaseDateTimeIn[Index]; if (UseGMTTime.GetBoolean() != 0) BaseDateTimeIn = sc.AdjustDateTimeToGMT(BaseDateTimeIn); BaseDateTimeIn.GetDateTimeYMDHMS_MS(Year, Month, Day, hour, minute, second, millisecond); SCString DateString; switch (DateFormat.GetInt()) { case 0: DateString.Format("%02d/%02d/%d", Month, Day, Year); break; case 1: DateString.Format("%d/%02d/%02d", Year, Month, Day); break; case 2: DateString.Format("%02d/%02d/%d", Day, Month, Year); break; } // write bar data string to file int ValueFormat = sc.BaseGraphValueFormat; char MillisecondsText[32] = {0}; if (OutputMilliseconds.GetYesNo()) sprintf_s(MillisecondsText, ".%d", millisecond); const char *FormatString; switch (Separator.GetInt()) { case 0: FormatString = "%s %.2d:%.2d:%.2d%s %s %s %s %s %.0f %.0f %.0f %.0f\r\n"; break; case 1: FormatString = "%s, %.2d:%.2d:%.2d%s, %s, %s, %s, %s, %.0f, %.0f, %.0f, %.0f\r\n"; break; default: case 2: FormatString = "%s\t%.2d:%.2d:%.2d%s\t%s\t%s\t%s\t%s\t%.0f\t%.0f\t%.0f\t%.0f\r\n"; break; } float OpenValue = IsRenko ? sc.BaseData[SC_RENKO_OPEN][Index] : sc.Open[Index]; float HighValue = sc.High[Index]; float LowValue = sc.Low[Index]; float CloseValue = IsRenko ? sc.BaseData[SC_RENKO_CLOSE][Index] : sc.Close[Index]; SCString BarDataString; BarDataString.Format(FormatString, DateString.GetChars(), hour, minute, second, MillisecondsText, sc.FormatGraphValue(OpenValue, ValueFormat).GetChars(), sc.FormatGraphValue(HighValue, ValueFormat).GetChars(), sc.FormatGraphValue(LowValue, ValueFormat).GetChars(), sc.FormatGraphValue(CloseValue, ValueFormat).GetChars(), sc.Volume[Index], sc.NumberOfTrades[Index], sc.BidVolume[Index], sc.AskVolume[Index]); WriteFile(FileHandle, BarDataString.GetChars(), (DWORD)BarDataString.GetLength(), &BytesWritten, NULL); } CloseHandle(FileHandle); return; } |
