Date/Time: Sun, 28 Apr 2024 10:30:48 +0000
TD Ameritradew
View Count: 581
[2018-03-30 15:13:05] |
User606150 - Posts: 6 |
Hello I have been using Sierra Charts for some time with no complaints. But TD Ameritrade does not supply futures data for use with Sierra Charting. I understand from your site that I can add a data package to add futures data. Can you direct me to the spot on your site for adding the futures data package to work with TD Aneritrade? Thanks H. Hampton. |
[2018-03-30 22:40:06] |
Follow through the instructions here: Sierra Chart Exchange Data Feed: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
