Date/Time: Thu, 09 May 2024 01:45:44 +0000
enabled studies
View Count: 729
[2018-03-30 01:24:43] |
User63632 - Posts: 43 |
Have enabled studies for download on start up...but does not work. Does this feature work with Transact/Infinity as data provider? Thank you |
[2018-03-30 22:41:34] |
We do not know what studies you are looking for.
[2018-04-01 00:57:11] |
I have studies from a 3rd party developer. He has suggested that I enable SC account settings control panel This setting controls whether files are downloaded on software startup. which I have completed, so that when he updates a study and I update SC, the study will automatically update as well. Instead of him sending out a update file and then I need to copy and drag it to the data folder. Thank you |
[2018-04-01 01:39:50] |
For us to help and understand this better, you need to log into this Support Board directly from Sierra Chart. Use Help >> Support Board and post a response here saying that you have done that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-01 01:40:03
[2018-04-01 18:06:37] |
User358559 - Posts: 15 |
[2018-04-02 07:19:00] |
Sierra Chart - Max - Posts: 5608 |
Your Sierra Chart account is not authorized for any 3rd party custom studies: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies#ThirdPartyStudiesEnabledForAccount Contact the developer and make sure that they have authorized your current Sierra Chart account. Sierra Chart Support |
