Date/Time: Sun, 05 May 2024 08:51:13 +0000
Volume By Price not showing in Large Number Display Format
View Count: 628
[2018-03-29 17:35:06] |
Guilherme - Posts: 66 |
Hi. I tried setting the Large Number Display Format in Volume by Price indicator, but it does not work.
2018-03-29_14-31-16.png / V - Attached On 2018-03-29 17:34:28 UTC - Size: 110.57 KB - 293 views |
[2018-03-29 18:06:40] |
The values need to be over 10,000 before that takes effect. This is documented.
