Date/Time: Sat, 04 May 2024 19:02:19 +0000
BitMex: Please update Altcoin Futures
View Count: 665
[2018-03-29 13:25:15] |
User732495 - Posts: 6 |
Hi guys, Bitmex has listed several Altcoin contracts for the JUN29 expiry, all of them are live and trading but I cannot trade them via SC since SC doesn't list the symbol. I also tried to do it manually without success. Can you please look into it and update it asap (meaning BEFORE the old contracts expire). We have positions and want to rollover. Thanks |
[2018-03-29 17:33:17] |
These symbols should now be listed. Check again.
[2018-03-30 09:48:00] |
It worked. Thanks for the quick response
