Date/Time: Wed, 28 Oct 2026 10:25:39 +0000
hotspotfx data
View Count: 1645
[2013-10-03 17:03:09]
User21223 - Posts: 97
Is it able to connect to the hotspot fx. which format to choose http://www.hotspotfx.com/technology/apifix.jsp
[2013-10-03 17:22:19]
Sierra Chart supports the FIX Bookfeed API format. You will see a service listed in Global Settings >> Data/Trade Service Settings named "Hotspot FX".
[2013-10-04 05:12:44]
I can not connect to the hotspotfx
Massage Log:
Connecting to HotspotFX... | 2013-10-04 06:09:38
The network socket is connected. | 2013-10-04 06:09:38
FIX Session: Sending the Logon message. | 2013-10-04 06:09:38
FIX Session: Received a Logout message. Text = Invalid instance name. | 2013-10-04 06:09:38
FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-10-04 06:09:38
FIX Session: Logged out and disconnected. | 2013-10-04 06:09:38
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-10-04 06:09:38
To prevent further connection attempts, select File >> Disconnect. | 2013-10-04 06:09:38
Disconnected from HotspotFX. | 2013-10-04 06:09:38
[2013-10-04 05:33:16]
Have you contacted Hotspot about this? They have to provision you a FIX account. They may also have to allow your IP address. This is not a simple connection to achieve.
This is the relevant message to communicate to Hotspot:
Date Time Of Last Edit: 2013-10-04 05:33:49
[2015-12-22 17:58:26]
We do not know the answer to this.
