Date/Time: Sat, 18 May 2024 13:54:20 +0000
How to Stop Replay from starting backtest on launch ?
View Count: 1290
[2018-03-28 13:29:21] |
User651753 - Posts: 77 |
When I go to Replay backtest, the default startup and laggy out my computer. Then I have to press Stop and then adjust date and speed is there a way to stop it from auto starting with defaults? |
[2018-03-28 19:26:06] |
You need to do the back test following the method here instead: Auto Trade System Back Testing: Replay Back Testing - Manual Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-29 08:49:50] |
Yea they are the step I normally take, it uses to just sit there and wait for me to start however now it starts backtest straight away when launching and i have to "STOP" so i can select the date and speed , I am also running a 2nd copy on my VPS and this doesn't happen. So i have done something to enable this but I don't know how to turn it off. |
[2018-03-29 08:59:53] |
however now it starts backtest straight away when launching Describe the steps you are following. This is not clear what you mean by this.
[2018-03-29 10:18:31] |
these are the step I am doing https://imgur.com/a/lvm2g does it normally start runing back the backtest . or do you have to press "play" because mine start straight away with 7680 speed and completely lag out my PC is there a way for it not to start on launch and only start after I click "PLAY" |
[2018-03-29 10:38:09] |
Once again here is the documentation: Auto Trade System Back Testing: Replay Back Testing - Manual ( Replay Back Testing-Manual) Follow the steps exactly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-29 10:45:05] |
Oh so when you do it my way it auto reply back test , thanks for your help |
