Date/Time: Fri, 03 May 2024 11:59:10 +0000
trades are deleted when switching to replay mode
View Count: 691
[2018-03-28 05:40:28] |
User534083 - Posts: 4 |
Hello, when I switch to replay mode all trades (in sim) are being deleted from trade history. How can I prevent this? How can I keep my trade history using the replay mode? Thanks, jn |
[2018-03-28 09:56:10] |
Sorry, I think I can answer this for myself. After enabling Replay I'm asked to delete my trades. If I answer "no" all trades will remain. Correct? Thanks, jn |
[2018-03-28 18:56:40] |
Make sure the Replay Mode is set to Standard Replay: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayMode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-25 23:32:53] |
User379468 - Posts: 508 |
Is it possible to remove the popup dialog box asking to delete trades when starting a replay? I have accidentally deleted trades I need to keep more than once due to unwanted popup dialog. Also, the option to instead delete trades and be able to select from which account in the replay control bar would be very helpful. Also ability to rename the accounts would be great. |
