Date/Time: Wed, 15 May 2024 13:47:08 +0000
Release 1725 - Are BidDOM and AskDOM no longer members of the s_SCBasicSymbolData?
View Count: 817
[2018-03-26 15:39:00] |
Zosimus - Posts: 345 |
A study that I wrote that is using sc.SymbolData->BidDOM and sc.SymbolData->AskDOM. After upgrading to 1725 it is suddenly not working properly and when trying to build it on 1725 I'm getting a message that BidDOM and AskDOM are not members of s_SCBasicSymbolData. when I look at scsymboldata.h I see declaration of Old_AskDOM and Old_BidDOM. |
[2018-03-26 15:58:53] |
Refer to: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1718 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-18 05:40:36] |
User921987 - Posts: 234 |
Did I understand right that even the sc.SymbolData->Old_BidDOM/Old_AskDOM arrays still exists they are not functional ie. should not be used ?
[2018-08-18 07:10:12] |
Yes this is correct.
