Date/Time: Tue, 07 May 2024 00:10:11 +0000
Please again:add any btc broker and inform that bitmex isn't at alpha stage
View Count: 1280
[2018-03-25 14:54:18] |
User271989 - Posts: 44 |
Trade Activity Log: File read result: 21727 records inserted. 2835 fill records inserted. 0 records filtered. | 2018-03-23 17:39:48 Trade Activity Log: File date-time limits: Sim records date-time limit is 2018-03-08 00:00:00. Non-sim records date-time limit is 2017-12-20 00:00:00. Non-sim fill record date-time limit is 2017-03-23 00:00:00. | 2018-03-23 17:39:48 New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3782. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-23 18:13:41 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3783. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-23 18:56:07 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3785. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-23 23:58:30 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3792. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-24 02:59:29 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3803. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-24 20:31:40 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3805. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-24 21:26:16 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3806. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-24 23:53:41 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3807. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-24 23:56:54 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3808. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-25 00:07:30 * New order rejected - BitMEX Trading Direct error: The system is currently overloaded. Please try again later. Internal Order ID: 3811. Service Order ID: (none). Symbol: XBTUSD-BMEX | 2018-03-25 02:59:45 * |
[2018-03-25 14:55:20] |
Auto trading on bitmex is not even at alpha stage
[2018-03-25 20:02:42] |
At this point really our decision is not to work with any crypto currency exchanges. None of them meet our standards. We are working on developing our own exchange functionality. We are not going to waste time with the trash that is out there now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-26 20:03:31] |
only today i found the update about bitmex problem "We are working on developing an alternative connection method to BitMEX which will eliminate all connection issues. We expect this to be ready no later than the end of April 2018." Bitmex CTO said on Reddit that the problem is the calculation of all margin requiriment of all opened orders on all crosses. Will SC new connection method have an impact on it and really solve all problems with rejection of orders? Thanks in advance |
[2018-03-27 00:41:16] |
We do not think the connection model is going to change what you are experiencing.
[2018-03-30 02:25:48] |
Any prediction of when this will be available? Wich forex or futures partner has low fees and are suitable for accounts with less than 10.000 usd? |
[2018-03-30 21:25:32] |
We are only working on the software part of the exchange at this time. Initially it will be used for simulation purposes. This is all we are prepared to say at this time. Wich forex or futures partner has low fees and are suitable for accounts with less than 10.000 usd? If you are able to open a 10,000 USD account you can use LMAX which now has crypto currencies CFDs:LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-30 21:26:01
