Date/Time: Sun, 19 May 2024 15:10:08 +0000
Left SideScale Precision with Crosshair
View Count: 999
[2018-03-23 18:13:03] |
lpfin123 - Posts: 59 |
Good afternoon, The attached picture will help understand my question. I have a left side scale and a right side scale. When I use my crosshair, the value on the right side scale is correct, but the one on the left is not (it goes by 1.00 increment). If you look at the picture, with the left side scale, my crosshair is between 1.10 and 1.50, but the "highlighted value" given with the crosshair is 1.00. Is there a way to have an accurate value on the left side scale? Thank you, |
18-03-23, Fri, 14-06-35.JPG / V - Attached On 2018-03-23 18:07:44 UTC - Size: 203.47 KB - 279 views |
[2018-03-24 11:17:18] |
Provide us that chart by following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-25 13:34:14] |
File attached
Private File |
[2018-03-27 00:26:31] |
This is because the left side scale is being rounded to the tick size of the chart. We will remove that from the left side scale.
