Date/Time: Sun, 28 Apr 2024 18:08:49 +0000
Chart trade window
View Count: 759
[2018-03-23 16:22:35] |
This makes no sense whatsoever. What operating system are you running Sierra Chart on? We never heard of such a thing. Nothing has changed which would cause this. One thing we want you to do is select Chart >> Reset Child Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-23 20:14:31] |
If you are using Windows 10, this only shows the deteriorating situation with Microsoft and their software. This is totally and completely an issue on the operating system side. It is clear, that Microsoft is on a destructive path and eventually it is no longer going to be a stable platform for other programs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-24 21:21:02
