Date/Time: Mon, 29 Apr 2024 20:29:39 +0000
clore Background based on alert
View Count: 657
[2018-03-22 21:50:11] |
User913831 - Posts: 37 |
Hi, I am having issue on a simple query, which for some reason stop in time. the alert is simple =crossfromabove (ID12.SG2,ID12.SG1) ID12 being Stochastic momentum it works fine (produce bar on chart). However it does stop producing alert at a given time point in the past for all period backward from this time (one day) could you help Thanks |
[2018-03-23 02:19:39] |
You need to increase the Number of Bars to Calculate Input: Color Bar Based on Alert Condition: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-23 02:19:49
