Date/Time: Wed, 08 May 2024 07:57:00 +0000
Trade Activity Log Orders type greyed out?
View Count: 1352
[2018-03-22 14:17:20] |
User509820 - Posts: 69 |
When I have trade activity log open, when I click on any tab (trade statistics, trades, period trade stats, etc) The orders pull down is grey out. I cannot see my stats for the year or any full information. I have it set to my correct account and symbols I want to show. It will not work anymore. Any suggestions?
[2018-03-22 20:54:16] |
You first need to go to the Trade Activity tab, the first tab, and set the controls as required to display the particular order fill activity you want and then go to the other tabs. This is all explained for the each tabs here: Trade Activity Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-22 20:55:00
[2018-03-22 23:17:25] |
Thanks that worked. I have multi computers load with Sierra Chart. How can I link all the trades from different computers together?
[2018-03-23 02:20:40] |
This requires exporting and importing the order fills. Refer to: Trade Activity Log: Importing and Exporting Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
