Date/Time: Sun, 19 May 2024 00:53:40 +0000
[User Discussion] - sierra chart visible chart price
View Count: 1603
[2018-03-22 13:39:04] |
User79074 - Posts: 105 |
Is there a way to get the top and bottom price that the chart is showing? The price range that the chart is showing?
Date Time Of Last Edit: 2018-03-22 14:06:30
[2018-03-22 18:20:44] |
JoseyWales - Posts: 67 |
Not sure if you wanted it as a Dll or as an ACSIL example, but this is something I came up with. Dll attached below. #include "sierrachart.h" SCDLLName("High/Low Values For Visible Bars") SCSFExport scsf_HighLowValuesForVisibleBars(SCStudyInterfaceRef sc) { SCSubgraphRef High = sc.Subgraph[0]; SCSubgraphRef Low = sc.Subgraph[1]; if (sc.SetDefaults) { sc.AutoLoop = 0; sc.GraphName = "High/Low Values For Visible Bars"; sc.GraphRegion = 0; sc.UpdateAlways = 1; // Graphs High.DrawStyle = DRAWSTYLE_VALUE_ON_HIGH; High.Name = "High"; High.PrimaryColor = COLOR_GREEN; Low.DrawStyle = DRAWSTYLE_VALUE_ON_LOW; Low.Name = "Low"; Low.PrimaryColor = COLOR_RED; return; } const int numberOfVisibleBars = sc.IndexOfLastVisibleBar - sc.IndexOfFirstVisibleBar + 1; int& indexOfPreviousHighestValue = sc.GetPersistentInt(0); const int indexOfHighestValue = sc.GetIndexOfHighestValue(sc.High, sc.IndexOfLastVisibleBar, numberOfVisibleBars); if (indexOfPreviousHighestValue != indexOfHighestValue) { High[indexOfPreviousHighestValue] = 0; indexOfPreviousHighestValue = indexOfHighestValue; } int& indexOfPreviousLowestValue = sc.GetPersistentInt(1); const int indexOfLowestValue = sc.GetIndexOfLowestValue(sc.Low, sc.IndexOfLastVisibleBar, numberOfVisibleBars); if (indexOfPreviousLowestValue != indexOfLowestValue) { Low[indexOfPreviousLowestValue] = 0; indexOfPreviousLowestValue = indexOfLowestValue; } High[indexOfHighestValue] = sc.High[indexOfHighestValue]; Low[indexOfLowestValue] = sc.Low[indexOfLowestValue]; } Date Time Of Last Edit: 2018-03-22 18:21:20
HighLowValuesForVisibleBars_64.dll - Attached On 2018-03-22 18:19:27 UTC - Size: 84.5 KB - 340 views |
[2018-03-22 19:16:18] |
Thanks for the reply. What I means it I would like to know that the price on the top of the chart is 64.54 and bottom is 64.06 like in this image
screen01.png / V - Attached On 2018-03-22 19:15:30 UTC - Size: 10.45 KB - 339 views Attachment Deleted. |
[2018-03-22 19:22:23] |
Download the Dll attached above to your Sierra Chart Data folder and add the study to your chart, it should be what your looking for.
Date Time Of Last Edit: 2018-03-22 19:24:33
[2018-03-22 19:48:05] |
I see now. The study I provided displays a value on the Highest and Lowest bars that are currently visible in the chart. It does not display the range of the current chart. There are two variables: sc.BaseGraphScaleRangeBottom ACSIL Interface Members - Variables and Arrays: sc.BaseGraphScaleRangeBottom and sc.BaseGraphScaleRangeTop ACSIL Interface Members - Variables and Arrays: sc.BaseGraphScaleRangeTop However they only have valid data if the user explicitly sets them. Date Time Of Last Edit: 2018-03-22 19:49:16
[2018-03-23 07:02:57] |
Thanks, I saw that, but that only works when using a User Defined scale. If it is set to automatic, seems to be no way to get the top and bottom of the price in the scale.
[2019-04-13 08:42:59] |
User735389 - Posts: 188 |
Try this: RECT rect; GetClientRect(sc.GetChartWindowHandle(sc.ChartNumber), &rect); float topValue = sc.YPixelCoordinateToGraphValue(rect.top) ; float bottomValue = sc.YPixelCoordinateToGraphValue(rect.bottom); |
