Date/Time: Fri, 03 May 2024 05:54:11 +0000
New version not downloading
View Count: 663
[2018-03-22 07:13:26] |
User44445 - Posts: 3 |
I have tried to download the new version of SC 1721 but it does not seem to be downloading. I get to the stage where I'm asked do you want to allow sierrachartsdownloder.exe to make changes to this computer, which I then say yes to, but nothing happens after that.
[2018-03-22 08:00:58] |
This is a random Windows issue. We have implemented a solution. To get the latest release use this installer directly: https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-22 08:01:22
