Date/Time: Sat, 04 May 2024 20:21:17 +0000
Bitfinex Trading Support
View Count: 2206
[2018-03-21 21:38:28] |
User952186 - Posts: 58 |
I'm currently testing different platforms for cryptocurrency trading. May I learn when Bitfinex trading option will be added? Thanks. |
[2018-03-22 03:32:31] |
Should be within 60 days unless there are technical complications.
[2018-03-22 08:08:50] |
Great! I'm looking forward to it. Thanks for prompt reply. Cheers. |
[2018-07-03 12:39:42] |
Hi again, Is there any update it is now more than 60days. I hope we can have it soon. Best regards, Ozgur |
[2018-07-04 06:17:36] |
We decided not to move forward with this, and we are working on our own exchange functionality which should be available for simulation purposes, in about a month.
[2018-07-04 07:35:50] |
Ok, thanks for the reply. I have my team of developers can you guide us to create our own integration with SC and Bitfinex API by developing our own middleware?
[2018-07-05 08:23:36] |
You need to develop a server that follows the DTC Protocol and then Sierra Chart acts as the client and connects to that server. Refer to this page: https://www.sierrachart.comindex.php/?page=doc/DTC_TestClient.php In regards to market data you would not have to integrate to that because we already have it but problem is we have to provide that in combination with the server you have for trading. Let us check to see if someone else has already developed a server for trading Bitfinex. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-05 08:25:14
[2018-07-06 06:44:23] |
Thank you, I am looking forward to hearing a news about it.
[2018-07-19 06:04:18] |
Have you had a chance to check whether someone else developed a server or trading or Bitfinex or not? Thanks. |
[2018-07-19 21:15:56] |
Yes. We decided to go ahead and proceed with this ourselves.
[2018-07-20 06:38:56] |
Sorry I'm a little bit confused. Will you be developing a server solution for trading at Bitfinex? If yes, when can we expect such a solution? Thanks. |
[2018-07-24 05:11:13] |
We are not really sure about the timing.
[2018-07-25 01:21:56] |
mountainwolf - Posts: 37 |
What are you working on? What r the unique aspects of the project in question? Would you consider establishing first ever completely transparent trading house? Sharing all the data -- swaps, stops yes, coldstorage even banking. This is the only way to completely eliminate the possibility of the ever-present so much appealing ever-lasting inside-trading.. all these xchanges are in fact enormous data-mining engines. some gain advantage by having access to such real-time market sampling data, while others -- general public don't. the playing-field is always skewed.. That would be a new era for markets evolution. Just imagine a market with egalitarian information. & by that i mean All data gotta be shared. We decided not to move forward with this,
it seems Sierra & we are working on our own exchange functionality.. has been developing its own trading engine.. Will you be developing
a solution for trading at Bitfinex? Date Time Of Last Edit: 2018-07-25 22:21:52
[2018-07-25 01:33:22] |
Sharing all the data -- swaps, stops yes, That is a good idea to include the stops in the market depth data. We will work on that. Although someone can just hide them by holding them client-side.coldstorage even banking. it seems Sierra
Yes. We will have a simulated exchange out, hopefully in about two weeks. We are just going to release our initial development and then progress along with further functionality and performance improvements.has been developing its own trading engine.. This is going to be a very high performance exchange with fast executions. And decentralized trading support is also coming. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-25 01:34:14
[2018-09-05 08:02:34] |
Any update about Bitfinex trading integration or SCs own exchange? Thanks. |
[2018-09-11 09:10:53] |
For Bitfinex trading support, there is another developer who may be working on this. We will direct them to this thread and see what they say. We are continuing to proceed to develop exchange functionality in Sierra Chart. We can only say at this time that we will be releasing this as a simulated exchange. This has been a good project because it has improved the trading functionality in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-12 06:13:42] |
Thank you. I am looking forward to hearing from him/her soon then.
[2018-09-12 16:29:07] |
Yes we have contacted them.
[2019-02-24 03:05:13] |
truth - Posts: 2 |
Hello, curious on any updates on Bitfinex trading with Sierra charts?
