Date/Time: Wed, 08 May 2024 11:29:22 +0000
Thinkorswim
View Count: 1337
[2018-03-20 14:03:20] |
User509820 - Posts: 69 |
Hi, does anyone use sierra chart integrated with thinkorswim? How is it? Can you use sierra chart fully or is it limited? I just haven't seen much of anyone using these two systems together. Thanks
[2018-03-20 18:00:50] |
There is support for TD Ameritrade and that is documented here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
