Date/Time: Sat, 18 May 2024 11:37:23 +0000
Update Chart Drawings to Current Symbol > for entire watchlist?
View Count: 1063
[2018-03-20 07:23:42] |
User961161 - Posts: 11 |
Hi is it possible to update chart drawings to current symbol for my whole watchlist or any other list of symbols? currently i need to do it one by one. regards Konstantin |
[2018-03-24 11:50:59] |
also is there an option to add it to the control bar? i couldn t find it under customize control bar.
[2018-03-26 04:51:16] |
There is this setting: Show Chart Drawings for Different Symbols: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-26 04:51:30
[2018-03-26 09:46:37] |
i tried this option to show chart drawings for different symbols but i need to show only for different month, not all drawings for any other symbol. can i limit it somehow to show only for e.g. es instead if any other symbol?
