Date/Time: Thu, 02 May 2024 11:21:37 +0000
backest trade log switch off
View Count: 714
[2018-03-19 21:03:02] |
User30743 - Posts: 364 |
hi, how will i switch off all the messagess that sierra sends to my trade service log while performing an auto-backtesting? there are quite some ammount of lines and i guess it is slowing down the becktest. i have been performing backtest for a simple price action condition and this log sort of irritates me.. i mean, i dont need it there. i have set everything up in the code so i dont need sierra to send something to the log, moreover if it does send 1000x time the same message.. Date Time Of Last Edit: 2018-03-19 21:04:54
[2018-03-19 23:14:11] |
You most definitely cannot suppress this and we would never allow this under any conditions. In this particular case you must avoid flattening the Trade Position under the conditions in which this error will occur. This is your responsibility and this is fully within your control. This is for you to solve. You should not be trying to flatten the Position when it cannot be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-19 23:14:56
[2018-03-20 11:29:18] |
it is not only about flattening a position, it pops up also on another thing, basically all things that are specified in the bool type automatic trading variables - but they have to be set up in a particular way in order the system does what i want it to do..
[2018-03-20 17:45:48] |
You need to add checks to prevent any order actions under those conditions as well.
