Date/Time: Mon, 29 Apr 2024 11:18:03 +0000
Incorrect Total numbers on DOM
View Count: 724
[2018-03-19 08:25:53] |
ticinotrader - Posts: 378 |
When using the 1720 prerelease, the DOM totals are showing incorrect values - several millions of contracts and the number continuously increases. http://www.sierrachart.com/image.php?Image=1521447775476.png |
[2018-03-19 10:11:44] |
Acro - Posts: 436 |
Same for me ticino. This applies to every instrument I have used the DOM on and whether it is a standard DOM or a Chart DOM |
[2018-03-19 10:29:41] |
Marmany - Posts: 303 |
+1
[2018-03-19 15:22:22] |
We have this now resolved and we will have a new release out in a couple of hours.
[2018-03-19 16:47:36] |
We have released a new revision of 1720. The version number is the same. You need to update again to the latest "Prerelease": Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
