Date/Time: Wed, 01 May 2024 00:42:33 +0000
Problem with Automatic/Built-in Updater
View Count: 676
[2018-03-19 08:23:23] |
ticinotrader - Posts: 378 |
When I try to use the Help -> Download Current or Download PreRelease options, I always get the following error message: Failed to open the file: C:\SierraChart\SierraChartFileDownloader.exe. Error: Windows error code 32: The process cannot access the file because it is being used by another process. | 2018-03-19 04:08:07 * Although I can manually download the installer from your site and run it. I get this message when trying to up/downgrade on 1716, 1717 and 1720 |
[2018-03-19 20:48:07] |
This is going to be due to some security software on your system.
