Date/Time: Thu, 02 May 2024 23:25:15 +0000
Why would a Flex Renko Chart look like that ?
View Count: 2295
[2013-04-05 12:42:04] |
buylosellhi - Posts: 60 |
pls see attached.
CAD_chart.png / V - Attached On 2013-04-05 12:41:54 UTC - Size: 38.87 KB - 837 views |
[2013-04-05 12:43:43] |
pls see attached with annotation...
CAD_chart2.png / V - Attached On 2013-04-05 12:43:40 UTC - Size: 51.36 KB - 793 views |
[2013-04-05 17:31:27] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Make certain you have the proper settings for tick by tick data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
