Date/Time: Thu, 02 May 2024 02:17:26 +0000
Copy drawings from other charts hide issue
View Count: 1022
[2018-03-15 19:26:30] |
samual sprat - Posts: 343 |
Hi, When I copy drawings from one chart books to a another chart or chart on another CB using chart settings, if I try to hide the drawings from the other chart using the chart menu > "Hide Drawings From Other Charts" then they become invisible as expected but you can still move the drawings by mistake. I noticed this while using the hand tool to move the chart around and I accidentally dragged a line from another chart. I have option the option from chart settings to "Allow modification of chart drawings from other charts". Also have some options set in tool settings: 'support left click to select chart drawings', 'support drag to start drawing creation/modification', 'require drag to start drawing creation/modification', 'double click brings up drawing properties'. Please be nice if I have this wrong - I've taken the time to point this out and have looked into all the copy drawing settings Thanks S |
[2018-03-15 20:49:38] |
It does sound like there is a problem here we need to look into. We will resolve this.
[2018-03-20 08:57:43] |
This has been resolved in the latest prerelease.
