Date/Time: Sun, 05 May 2024 18:01:06 +0000
5 Min Time Intervals on Numbers of Trades per Bar Chart
View Count: 701
[2018-03-15 14:42:46] |
User172040 - Posts: 70 |
I use the Numbers of Trades per Bar chart period type. As this period type is not time sensitive I want to see a vertical line every 5 minutes from 09:30 until 16:00. I have seen the Time Interval study and that will work for 1 period. But if I want 5 minute vertical lines plotted from 09:30 to 16:00 I'll have to duplicate that study 78 times and fill in the time 5 minutes at a time in all of them. Is there a study that does this all in 1? I searched your history as well and did not find any topics on this. Thanks |
[2018-03-15 18:30:43] |
You need to use the Vertical Grid for this: Chart Settings: Show Vertical Grid (Chart >> Chart Settings >> Grid >> Show Vertical Grid menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
