Date/Time: Sat, 18 May 2024 06:00:09 +0000
streaming 1H quotes of crypto-currencies to a CSV file
View Count: 671
[2018-03-14 10:13:30] |
User449734 - Posts: 5 |
Dear Support, Could you please advise how can I stream quotes from Sierra in real-time to a csv file? (I'm interested in 1h crypto-currency charts.) Would it be possible to stream a few instruments to various files at once from the same or multiple instances of Sierra? It would be really helpful if you provide a detailed step-by-step instruction. Thank you! |
[2018-03-14 17:46:21] |
You can use the Write Bar Data to File study: Write Bar Data to File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
