Date/Time: Sat, 04 May 2024 01:41:31 +0000
Canadian Broker ? other than IB
View Count: 767
[2018-03-14 18:40:27] |
Not really sure other than Interactive Brokers. You probably really do need to use them. You should go to the Interactive Brokers website and look up the information you need. Here are the set up instructions to use Sierra Chart with Interactive Brokers: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
