Date/Time: Tue, 07 May 2024 09:00:25 +0000
futures volume
View Count: 715
[2018-03-11 15:59:36] |
User259724 - Posts: 43 |
It is suggested with futures volume to use the volume of all contracts. I see that on the historical continuous charts on end of day data that I refer to that the volume is only based on the current contract and not the sum of all contracts combined. Is it possible to configure the volume to all contracts instead of only one single contract? Thank you in advance. |
[2018-03-14 18:37:24] |
This is not supported.
[2018-03-15 17:53:16] |
Actually, this is not supported with the Continuous Futures Contract feature but it is supported for individual futures contracts. Refer to the instructions here: Charting Total Volume and Open Interest Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-15 17:53:52
