Date/Time: Mon, 20 May 2024 09:08:38 +0000
cannot download install 1714
View Count: 664
[2018-03-08 13:24:27] |
User99934 - Posts: 227 |
Get this error: Failed to open the file: C:\SierraChart\SierraChartFileDownloader.exe. Error: Windows error code 32: The process cannot access the file because it is being used by another process. | 2018-03-08 08:20:03 * |
[2018-03-08 16:29:10] |
This is going to be caused by security software running on your computer. Disable that security software temporarily. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-08 16:29:31
[2018-03-08 16:48:35] |
disabled it and still same problem. Nothing has changed on my computer.
[2018-03-08 20:02:55] |
Just use the installer direct from this page: Software Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-08 20:10:06] |
Installer direct worked fine.
[2018-03-08 23:29:57] |
This confirms it was security software on your computer causing the problem.
