Date/Time: Mon, 20 May 2024 09:08:43 +0000
Camarilla Pivots / Copy of Study
View Count: 1637
[2018-03-07 11:42:02] |
User371906 - Posts: 141 |
Hello, Would be highly appreciative if someone could please give me copy of a working Camarilla Pivots study. Can not get my mine to work appropriately. Thanks g |
[2018-03-07 20:07:41] |
Here is the documentation for the Pivot Points study: Pivot Points Can not get my mine to work appropriately. Why do you say this? We need more details.
[2018-03-07 20:18:35] |
Good evening, Appreciate reply. I have look at these pages you sent me and also the one page were you do manually the calculation but after 1 month I have been unable to get the pivot points to read correctly even with all the info you sent me. Is it possible if you have a template study I could try? Below the pages you sent me before. Kindly g We can only refer you to the documentation here about this: Pivot Points are not Accurate or are Different Run through the calculations manually using the formula documented here: http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#Formula_5 The first step is to add one of the Pivot Points studies to the chart: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies The Camarilla Pivot Points are determined by Formula Type 5, as explained here: http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#Formula_5 To get these Pivot Point lines in either the Pivot Points – Daily or Pivot Points – Variable Period studies, you need to set the value of the Formula Type Input to 5 in the Settings window for the study. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#SettingsandInputsTab |
[2018-03-08 21:12:01] |
I have look at these pages you sent me and also the one page were you do manually the calculation but after 1 month I have been unable to get the pivot points to read correctly even with all the info you sent me. Why is this the case? Mathematically explain based upon the formula and the Open, High, Low, or Close in the chart , why there is a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
