Date/Time: Mon, 20 May 2024 11:11:08 +0000
User Question
View Count: 601
[2018-03-06 20:35:34] |
Sierra Chart - Max - Posts: 5618 |
Hi and Good afternoon,
I wanted to thank you all so much for designing such and incredibly fast and solid product. I have used Esignal for 10 years, ninja, and OEC trader recently, and I am kicking myself mentally for not giving your superior product a try much sooner. Your product beats all of these hands down, and I spent thousands of dollars at EISIGNAL!! I am so impressed with the ease of use and just how "FAST" the charts draw and perform mathematical functions with ease!! THANK YOU. I tried to find the answers in the faq DATABASE but still was a little unsure of the answers I found. 1. When I set up a layout or chartbook if I have a couple chart books tabbed. Do the tabbed chartbooks that are CLOSED actually grab any bandwidth or update while they are closed? I am guessing they do not. I do not want to slow down the program by having lots of tabbed chartbooks if they will be updating in the back ground. 2. I researched charts on the q & a but couldn't find a direct answer for this question? How do I add a control bar with drawing tools to each chart so I do not have to go all the way back to my other screen in order to draw a trend line? 3 If I set up my charts and chartbooks in your 32 bit version will they transfer over to your 64 bit version? also I avhe a 64 bit machine but my download for trial was the 32 bit version. 4. will your new 64 bit version allow more than 4 gb of memory to be utilized if needed and will it have multi core capability now or possibly in the future? thank you Sierra Chart Support |
[2018-03-07 05:49:19] |
1. Charts which are not visible use very little processing time. 2. This is documented here: Control Bar: Window >> Control Bars >> Control Bar [1-8] 3. Yes. No problem. Also each installation of Sierra Chartincludes both the 32 and 64-bit version. There are shortcuts for both on the desktop. If you do not see them install the current version: Software Download: Fast Update 4. Yes this is now all supported. When responding be sure you post your response on this page. You will first need to login. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-07 05:50:18
