Date/Time: Tue, 30 Apr 2024 23:34:40 +0000
Hide Account number
View Count: 2009
[2018-03-06 06:48:58] |
User78442 - Posts: 260 |
Hi is it possible to hide all/part of my account number on the Chart trading window .. like AB24***** etc...
[2018-04-21 09:51:48] |
I have had no response to this post..
[2018-04-23 18:53:01] |
No, we have occasionally had this request so we will have to see about it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-23 18:53:07
[2019-01-10 22:11:28] |
BenjaminR - Posts: 168 |
Requesting also. I publish video analyses & to change charts takes time, & sometimes a trade window is overlooked. Please make this an option. Thank you.
[2019-01-14 02:10:34] |
The problem is if we add an option to hide this, you will not even be able to change the Trade Account and that creates a new problem.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-14 02:10:43
[2019-01-14 05:46:06] |
FYI the save chart to file function automatically strips any chart trading window. Videos are a different issue.. (I don't do videos...)
[2019-01-14 11:12:26] |
Engineering: Perhaps you mean the problem is not being able to distinguish between accounts. In that case, as I have seen other platforms do, perhaps obscure the account number partially. Example: "123*****". In the rare instance someone has several accounts, & they begin with the same 3 numbers... perhaps add the option to obscure the first several numbers or the last several numbers. Thank you, Ben |
[2019-08-02 14:09:55] |
User294333 - Posts: 5 |
Did this ever get implemented?
[2020-05-16 00:09:59] |
User75002 - Posts: 117 |
Hello, I'd like to revive this topic as the feature would be nice to have for privacy. Maybe if the numbers can't be masked due to complexity with multiple accounts, we could create an alias so that we can give it our own alphanumeric value? Thanks! |
