Date/Time: Mon, 20 May 2024 09:37:24 +0000
Connected but no data updates
View Count: 677
[2018-03-05 16:32:12] |
User431632 - Posts: 1 |
I am able to connect to the data feed - the status bar is green, inside it is: DF:27 ST:1,1 but the chart is not updating. It downloads historical data and that is all. The QuoteBoard shows Symbol and Time but the Last Daily/Change and Bid all show 0.0 I have been through the instructions located here - Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart but have not found a solution. Please advise. Thank you. |
[2018-03-05 16:45:56] |
Refer to: Real-Time Data Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
