Date/Time: Tue, 10 Nov 2026 16:34:53 +0000
Cumulative Delta Ticks High Issue
View Count: 1252
| [2018-03-05 13:23:26] |
| User536105 - Posts: 36 |
May I ask if I use a five minutes candlestick bar and I choose Cumulative Delta Ticks High function, does it mean that the value indicates how many times the price had moved from a lower tick price to an upper tick price within these five minutes? If not, is there any number bar indicators which may help me to arrive the same function? Thank you for your help my friend.
| [2018-03-05 18:21:54] |
We are not totally sure what study you are referring to. Here is the documentation for Cumulative Delta Bars - Up/Down Tick Volume: Cumulative Delta Bars - Up/Down Tick Volume We do not have any other information available. It sounds like you might be interested in this study instead: UpTick Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-03-05 18:34:47] |
Sorry. I forgot to mention it's in the number bar calculated values as I cannot see it in the manual.
| [2018-03-06 02:31:08] |
Refer to the Subgraph descriptions here for the Numbers Bars Calculated Values study: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions Though Subgraphs are documented and have also just been updated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-06 02:31:21
