Date/Time: Sun, 19 May 2024 02:02:06 +0000
SierraChart 64 and Trade Activity
View Count: 1485
[2018-03-02 09:27:56] |
AlexPereira - Posts: 197 |
Hi, I am testing 64 bit version of SierraCharts and all seems well, except the trade activity window. It shows no trading activity records, while changing to the 32 bit version shows all my trading activity. Is it a known bug/problem ? Thanks! |
[2018-03-02 19:43:23] |
We are not aware of any problem like this and have not observed it and there are no other reports of this. Make sure the controls at the top of the Trade Activity Log are set correctly.: Trade Activity Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-02 19:43:36
[2018-03-03 09:33:52] |
I understand now why its not a known problem, it only happens on 64bit version on linux ( 32bit works like in windows ). If its any help, all controls allow to be set correctly, except P/L format ( is always blank with no selection available ). I know that you don't give support for linux. Thanks and sorry if wasted too much of your time. |
[2018-03-03 09:45:45] |
That's interesting. We would not expect a problem. One thing that we have recently become aware of is that when a user updates to the prerelease and then goes back to the current release, there is an incompatibility with the Trade Activity Log data file and they will lose some trade activity records. But the solution is just to restore a backup trade activity log file: https://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#MissingTradeActivityAndBackupFiles Not sure if that is what is happening in your case but letting you know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-03 09:46:27
[2018-03-23 13:09:29] |
User97962 - Posts: 5 |
Hi. I got the same issue on wine. Everything works well with 32bit version, but using the 64bit version the tabs in the trade activity log are not available. I tested two versions of wine (1.8 and 3.4) on multiarch-enabled debian stable. Best regards. |
trade_activity_log.png / V - Attached On 2018-03-23 12:59:38 UTC - Size: 5.19 KB - 313 views Attachment Deleted. |
[2018-03-23 16:09:00] |
We cannot help with post #5.
