Date/Time: Sun, 19 May 2024 21:02:45 +0000
Squish charts to 3 pts Scale
View Count: 986
[2018-03-02 05:51:34] |
User800328 - Posts: 50 |
Hi, Please see my chart image: http://www.sierrachart.com/image.php?Image=1519968011244.png If you see the side bar, the point Scale is 4 pts. I could ONLY squish the scale to 2 points. See here: http://www.sierrachart.com/image.php?Image=1519969777605.png How could I make the scale to 3 points ? Right now, I could only make to 1 point, 2 point, 4 points etc but I need to set the scale to 3 points. Can you please let me know ? |
[2018-03-02 10:46:34] |
Refer to: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
