Date/Time: Mon, 20 May 2024 09:34:30 +0000
SEll orders not filled
View Count: 1005
[2018-03-01 19:29:38] |
UserZiltoid - Posts: 57 |
Hello SC. Lateley on simulated orders the sell order is not being filled. see attached screen shot. Thanks! |
Attachment Deleted. no sell order filled.jpg / V - Attached On 2018-03-01 19:29:18 UTC - Size: 49.77 KB - 321 views |
[2018-03-01 21:05:11] |
JoseyWales - Posts: 67 |
Please see this link on how to upload a chart screenshot for the best clarity https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image |
[2018-03-01 21:37:23] |
For the reasons why an order does not fill, refer to: Trade Simulation: Why Fill and Order Prices Can Be Wrong or Unexpected / Orders Do Not Fill When Expected Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-02 08:09:14] |
Tried that already. didn't help
[2018-03-02 19:18:13] |
What did you try or examine exactly? The documentation is very clear on all of the reasons why an order may not fill. With what you are doing and the data that you see in the chart, and in combination with the documentation you have a better perspective on this than we do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-05 19:36:55] |
We have noticed that this issue only happens with the latest Sierra version. In the old one that we have moved back - version 1663 it doesn't happen. The issue is simple - we set a limit SELL order and it doesn't get filled regardless the prices on the chart. We have followed that above page and it didn't help. The only solution was to move back to version 1663. |
[2018-03-05 19:44:34] |
Provide detailed step-by-step instructions on how to reproduce the problem. We need detailed instructions that tell us specifically what you are doing including opening the chart and the particular symbol. And if you are replaying a chart we need to know that as well. We need clear instructions, otherwise we cannot help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-05 19:44:57
[2018-03-07 20:54:27] |
We have been contemplating this, and it occurred to us that maybe there is a problem when orders are submitted from a sub instance or through the DTC server. When simulated orders originate through the DTC server the orders are not filling. This is now resolved. We will be releasing version 1714. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-07 21:00:06
