Date/Time: Mon, 20 May 2024 07:12:57 +0000
BITFINEX missing months in Daily (ZECUSD , DSHUSD, XMRUSD, ...)
View Count: 526
[2018-03-01 12:08:25] |
User612903 - Posts: 51 |
Hello, I'm connected to the Crypto service in Sierra. In the bitfinex feed, most of the ticker, are missing months in daily. Like ZECUSD for example, there are no data from 2017-08-19 to 2018-01-10. Is this a problem with the bitfinex feed ? Will this be fixed or just stay like this ? Thanks for your help, Regards, |
[2018-03-01 20:05:31] |
It will stay like this. Sierra Chart does not have this data.
