Date/Time: Sun, 05 May 2024 00:28:34 +0000
Kiwi Resync Study - Memory leak?
View Count: 3901
[2019-03-20 00:36:22] |
Willson - Posts: 176 |
Sending a forbidden BIG thankyou to Kiwi, sstfrederik,user212764 all that helped a lame programmer thru this. It now works
[2019-08-02 10:15:20] |
samual sprat - Posts: 343 |
You can use the 'Chart Recalculation - Periodic' study instead, does the same thing and it's built into sierra now
[2019-08-26 21:31:50] |
User132748 - Posts: 159 |
Dear SC, Chart Recalculation - Periodic study causes 100% CPU load, I guess because theres sc.UpdateAlways=1 inside code. Is this really needed? I guess it should be ok to do time calculation at standard chart updates? Thanks |
[2019-08-27 17:57:37] |
If it causes that kind of a load, increase the Recalculation Time in Seconds for that study and also the Chart Update Interval: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) And refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often We will also add an option for that study to control whether it Updates Always. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-27 18:04:31
