Date/Time: Mon, 20 May 2024 05:07:26 +0000
Unwanted Lines on TPO Chart
View Count: 1266
[2018-02-27 18:35:12] |
User765038 - Posts: 22 |
Support, In the uploaded image of a TPO chart, I have highlighted with red elipses unwanted lines (with an arrow at the leftmost edge) that appear to be related to the closing price of the day, carried forward until intersection (though not on all days due to an offset?) http://www.sierrachart.com/image.php?Image=1519755356180.png I have tried various methods of deleting these lines, thus far without success. In a similar vein, I am having trouble changing the properties of other markers. Perhaps they are related to a "default" setup overriding chart settings. If you suspect this, where might this be accessed? Any and all help appreciated. Thanks and regards, Rod |
[2018-02-27 19:31:55] |
Provide that chart by following these instructions so we can look at this: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-28 20:46:46] |
Chartbook (To Support.cht) attached as requested. Please note that the unwanted lines (but not the also unwanted small red triangles associated with them) can be toggled on and off using the "Extend Value Area" function (none / until future intersection). But of course this also toggles off the valid Value Area lines. Thanks, Rod |
To Support.cht - Attached On 2018-02-28 20:41:50 UTC - Size: 30.43 KB - 234 views |
[2018-02-28 22:08:32] |
OK so yes those lines are the Value Area lines. So what is the question if you know how to remove them or change where they are extended to? The red triangle cannot be removed because that indicates the last trade price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-28 22:33:46] |
Another thing we notice is that you have the Profile Time Period set to 840 minutes rather than 1 Day. We recommend using 1 Day so that you do not have that very small separate TPO profile.
[2018-03-01 10:54:31] |
This latter comment has resolved the issue to my satisfaction. Sincere thanks, Rod |
