Date/Time: Thu, 02 May 2024 14:55:57 +0000
Numbers bars pullbacks etc
View Count: 2198
[2018-02-27 16:48:43] |
User884307 - Posts: 173 |
Hi, When using numbers bars, pullback column and "Numbers Bars Calculated values", is it possible to include the pullback column data in the numbers bars calculated values column? Cheers :-) |
[2018-02-27 17:59:03] |
Ok, just been thinking, maybe didnt exapand enough ....... yes you can enable pullback to display in numbers bars but there is nothing displaying for example "max askbid vol diff to closing A/B diff etc etc .... Its just blank ? Volume displays OK and so does bar duration (for example) but the other columns are blank? cheers |
[2018-02-28 14:28:46] |
Would it be possible to just clarify as to whether this problem is OR isn't a bug in the display or is an omission ???? Many thanks |
[2018-02-28 19:20:00] |
Not every Subgraph for the Numbers Bars Calculated Values study would be supported in the pullback column.
[2018-02-28 19:31:56] |
hi, thanks for replying. is there any reason for this? Cheers |
[2018-02-28 23:17:58] |
Yes there is because the particular values that are needed for AskBid Diff Maximum/Minimum to Close Difference are not maintained for the pullback column, but we will do that and get this working in the next release.
[2018-03-01 16:39:45] |
Just updated to 1708, do you know when this will be enabled? Cheers 👍👍👍 |
[2018-03-01 19:20:49] |
In about two more days.
[2018-03-02 10:39:56] |
Just got latest update 1709 and numbers bars calc value now displaying additional data in pullback. However, problem is that I just tried to display the following in the pullback column for example.... Max AskBid vol Different to Close AskBid vol Diff Min AskBid vol Different to Close AskBid vol Diff They both display the same numbers hence not calculating correctly, I haven't tried other data fields yet so don't know if anymore errors. Cheers 👍👍👍👍 |
[2018-03-02 13:21:51] |
..... just an update, in numbers bars calculated values with pullback column enabled... high/low pullback ask/bid vol Diff is not calculating either, just displaying zeros |
[2018-03-02 20:55:57] |
At times those values are going to be the same. That is not unusual. Here's an example of where they are different: http://www.sierrachart.com/image.php?Image=1520024090178.png The calculations are verified to be correct. high/low pullback ask/bid vol Diff is not calculating either, just displaying zeros Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-02 20:57:15
[2018-03-02 21:00:03] |
Inherently this cannot be supported for the pullback column itself: high/low pullback ask/bid vol Diff is not calculating either, just displaying zeros Only on the existing chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-29 20:39:07] |
User881696 - Posts: 16 |
Can the High / Low Pullback information be used for calculations in automated studies. This would be a great help to me. Thanks in advance.
